3
Ammonia Plant Start-Up Procedure
start-up ammonia process plant ammonia plant asu smr air separation unit steam methane reformer haber bosch process
#1 Baz
Baz
  • 3 posts
Posted 08 April 2025 - 12:36 PM
Hi
I (a student) am working on my final section of my design project which is completing a start-up procedure for an ammonia plant that I have designed.
The plant has an air separation unit for N2 production, steam methane reformer for H2 production, a carbon capture system for blue H2 production and removal of CO2 (rather than gray hydrogen and releasing CO2 to atmosphere) and finally the ammonia production is complete in the haber bosch process.
My question is, is there any guidelines to start-up procedures before the normal operation process.
Kind reagrds,
Basmalah.
Edited by Basmalah, 10 April 2025 - 07:02 AM.
#2 Pronab
Pronab
  • 166 posts
Posted 11 April 2025 - 11:44 PM
Baz,
There is specific start-up procedure in an Ammonia plant before normal operation. I assume it is an initial plant start-up. Follow the below guide lines:
1) Front end (from Primary reformer upto Methanator) start-up.
2) Rear end (Synthesis loop) start-up.
In Front end start-up you need to start Primary reformer with burner lit-up and activate primary reformer catalyst including hydrogenation & de-sulfurization catalyst reactors. Prior to that I will assume HTS & LTS catalyst reactors are ready- they are reduced condition. Paralell CO2 removal (in most ammonia plant it is Benfield or MDEA solvent) section are reday.
Primary reformer catalyst  temperature to bring at operating temperature(more than 800C, depending on the process). Start air introduce to secondary reformer followed by gas flow to HTS/LTS reactors and then CO2 removal section. Parallel Ammonia converter reactor heating up/ catalyst to be activated gradually.
Till now purified gas from CO2 recovery section( H2 & N2, traces amount of CO/CO2) will pass through Methanator where traces amount of CO & CO2 will convert to CH4. Once Syn gas (H2 & N2, free from CO & CO2) compressor start and ammonia reactor is ready to take on-line gradually divert flow to Synthesis (ammonia reactor) loop where ammonia will produce. I will assume Ammonia storage tank is ready to storage produced liquid ammonia( Temp:-33C & atm pressure).
Contact me for further clarifications.
Best wishes.
Edited by Pronab, 11 April 2025 - 11:49 PM.
#3 Baz
Baz
  • 3 posts
Posted 14 April 2025 - 01:19 PM
Pronab,
Thank you for the help.
#4 breizh
  • 6,890 posts
Posted 15 April 2025 - 01:40 AM
You may find good pointers in the link underneath.
https://www.asiaiga....m reformers.pdf
As a student, you should not be responsible for this kind of document. This is definitely the scope of senior process or Ops engineers/managers.
#5 Baz
Baz
  • 3 posts
Posted 17 April 2025 - 09:23 AM
Hi Breizh,
It is worth mentioning that this is a design project as part of my university course and this is not to be applied in industry.
It is for the sole purpose of developing an understanding of procedures and as part of the IChemE Chemical Engineering degree.
Regards to the shared link: Thank you for the help. I will read through it to improve my understanding.
#6 breizh
  • 6,890 posts
Posted 17 April 2025 - 10:01 PM
OK!
Not knowing your process, I cannot comment much but prior to start to feed any equipment,
you need to make sure you have all the utilities in place (steam, cooling water, chilled water, N2, electricity), all vent lines connected to specific discharge points (let say scrubbers), same for wastewater (treatment unit)
you need to make sure all the equipments are lined up as per PID (manual valves, drain valves,etc).
Very basic for safety reasons.
#7 EnggExp
EnggExp
  • 10 posts
Posted 17 July 2025 - 01:15 AM
Hi Basmalah,
You’re working on a very comprehensive and modern ammonia plant design, incorporating:
• Air Separation Unit (ASU) for nitrogen
• Steam Methane Reformer (SMR) for hydrogen
• Carbon Capture for blue hydrogen (low-emission)
• Haber-Bosch Synthesis Loop for ammonia
For your startup procedure section, here’s a structured approach and typical guidelines:
General Startup Philosophy
Startup is sequential and interlocked, meaning each unit must be stabilized before moving to the next. Safety, inerting, temperature ramping, and purge procedures are essential.
Typical Startup Sequence for an Ammonia Plant
1. Utilities Check and Startup
Start with making utilities available and in stable operation:
• Power supply
• Boiler(s): start generating steam
• Instrument air and plant air
• Cooling water systems
• Nitrogen (temporary cylinders if ASU not yet online)
• Flare system operational and lit
• DCS, safety systems, interlocks, and communications tested
• Start compressors and refrigeration system
• Gradually bring temperatures down to cryogenic levels
• Collect and store nitrogen product (some for purging and inerting)
Purging and Inerting of Process Equipment
• Use nitrogen to inert and purge:
• Reformer tubes and radiant box
• Synthesis loop
• Ammonia storage and pipelines
• Goal: reduce oxygen content to <1% (often <0.5%) to avoid explosive mixtures on hydrocarbon or hydrogen introduction
• Preheat reformer gradually using fuel gas and air or indirect firing
• Raise temperature slowly to avoid thermal shock to tubes
• Once hot enough, introduce steam and natural gas in proper ratio
• Monitor outlet for reformate composition
Shift Reactors & CO₂ Removal
• Heat up and activate shift catalyst (if high-temp/low-temp beds are present)
• Bring amine or PSA CO₂ removal systems online
• Ensure CO₂ is effectively removed before synthesis loop
Hydrogen and Nitrogen Mixing
• Blend N₂ and H₂ to the desired stoichiometric ratio (2.5:1 to 3:1)
• Monitor gas composition before entering synthesis loop
Synthesis Loop and Reactor Startup
• Inert loop first with N₂, then introduce syngas
• Bring compressor online gradually
• Raise pressure and temperature slowly in reactor
• Monitor catalyst bed temperatures to avoid runaway
• Start ammonia condensation and separation
Product Storage and Handling
• Ensure NH₃ tank(s) are pre-cooled
• Use boil-off gas handling systems if needed
• Monitor for leaks or overpressure situations
Critical Safety Points
• Oxygen must be fully purged before introducing hydrocarbons or hydrogen
• Avoid rapid heating to protect catalyst and mechanical equipment
• Ensure flare system is online before handling flammable gases
• Functional checks for emergency shutdown (ESD) systems must be complete
