Flow Through Normally No Flow Line
#1 iippure
iippure
Posted 08 April 2025 - 06:41 PM
I am doing hydraulic calculation by using number of tee branch/tee straight from isometric drawing. However, I am not sure about flow through normally no flow line e.g. branch to drain line, inlet of PSV, line with NC/LC valves, bypass line of control valve.
My question is that I have to count tee straight for flow through normally no flow line or not.
Thank you very much in advance.
  • 1,637 posts
Posted 08 April 2025 - 07:11 PM
A straight flow through a tee is still affected by the tee even if the branch is not flowing. Decide how precise and detailed you want your calculations to be.
#3 Dacs
Dacs
  • 457 posts
Posted 09 April 2025 - 11:36 PM
If the information is available, then I'd add it. As Pilesar said, straight flow tee does have an effect in fluid flow even if the branch is closed off.
#4 iippure
iippure
Posted 11 April 2025 - 07:54 PM
Thanks both of you for advice. I decided to input the normally no flow line.
#5 breizh
  • 6,940 posts
Posted 12 April 2025 - 02:56 AM
hi,
Consider this resource.
Happy Songkran, Sawasdee Pimai.
  • Attached File  tee.pdf   1.65MB   28 downloads
