Recommended Fluid Velocity
#1 crn
crn
Posted 16 April 2025 - 12:46 AM
I am interested in the recommended velocity in liquid pipelines. API 14 in table 2.3 states for suction line 2-3 ft/s and discharge 6-9 ft/s for centrifugal pumps. But my question is about pipeline pumping light naphtha, if the same figgers are applicable or not, as it is volatile liquid.
Somewhere I read it should be between 0.9-1.8 m/s. Is there a source for this recommendation somewhere? Thanks
  • 6,942 posts
Posted 16 April 2025 - 01:06 AM
Consider these resources.
https://www.cheresou...google_vignette
Often the requirement is expressed in Head loss, see table and standard shared.
note:
Pay attention to the risk associated with static electricity built up in pipe due to high velocity!
Some companies are using anti-static agents.
https://www.chevronw...on_from_CBT.pdf
https://www.issehs.c...t-Explosion.pdf
#3 carlos infante
carlos infante
  • 24 posts
Posted 03 May 2025 - 07:30 AM
Considered 1.5 m/s as initial liquid velocity value for sizing calculations.
carlos
