Material Balance With Reaction
material balance mass balance mass balance with reaction
#1 Kentucky08
Kentucky08
  • 16 posts
Posted 30 April 2025 - 08:59 PM
Good day, everyone.
I am currently doing a material balance of a transesterification section. The MeOH fed is excess. Based on the problem, MeOH is present in CME (biodiesel) in 5% mass weight while it is present in its by-product, glycerine, in 45% by mass weight. I calculated the values by two equations and two unknowns.
By Methanol balance:
0.05(CME) + 0.45(Crude Glycerine) = Amount of Excess Methanol
By OMB
ECNO+MeOH+Catalyst= CME+Crude Glycerine
I am able to calculate the amount CME and Crude Glycerine using these two equations; however, the amount of MeOH calculated is not same as amount of excess Methanol.
Can I ask for everyone's help?
Thank you so much!
  • 6,939 posts
Posted 30 April 2025 - 09:15 PM
Don't duplicate posts, please delete one.
BTW share with us the problem statement.
Don't use acronyms without explanation ( ECNO,FAME,CME,Etc), Glycerin or Glyceride ? mismatch word text  and excel sheet.
For those interested with the subject: Links underneath
 https://www.e-educat...gee439/node/684
https://journeytofor.../macromodx.html
The first link should suffice to support your calculation:
Note: MW fatty oil and Biodiesel are the same (#). Quantity of methanol used is the same (#) than quantity of Glycerin generated based on stoichiometry:
1-ton fatty oil+100 kg methanol > 1 ton Biodiesel +100 kg of Glycerin.
catalyst (NaOH) # 1% vs Fatty oil # 10Kg
Total quantity of Methanol used to produce 1 ton of Biodiesel # 100+ 0.45*100+0.05*1000 = 195 Kg methanol
