VFD insulating oil recycling system is mainly used to improve the properties of insulation oil. It can remove trace water, gas, particulate matters etc. from the insulating oil effectively and rapidly so as to boost performance of transformer, circuit breakers, mutual inductors, cable and capacitors which has insulation system. VFD oil filtration system specialize in purifying branded oil, insulating oil of high voltage and super high voltage transformer. Additionally, it is suitable for treating low viscosity lubrication oil and is a de-acid device.
Description
Model VFD series utilizes coacervation technology, coalescing technology, separating technology and refined purification technology. Comparing to Model VF series, it add ROOTS vacuum system, second stage of separating system to improve the effect of purification. To remove free, soluble water, carbon, free and dissolved gases and particulate matters from insulating oil effectively and rapidly.
Other Product Catalogue
Insulation Oil Series
VFD Double-Stage High-Efficiency Vacuum Insulation Oil Purifier
VFD-A Double-Stage Vacuum Insulation Oil Automation Filtration
VFD-R Double-Stage Vacuum Insulation Oil Regeneration Purification
VFD-T Double-Stage Vacuum Insulation Oil Purifier with Tester
GER Gas Engine Oil Regeneration System
Turbine Oil series
TF Turbine Oil Recondition
TF-A Turbine Oil Automation Reclamation
TF-R Turbine Oil Regeneration Reclaiming
Lubrication Oil series
LV Lubrication Oil Filtration
LV-A Lubrication Oil Automation Filtering
LV-R Lubrication Oil Regeneration Filter
Flame-resistant Oil series
FV Flame-resistant Oil Recycling
FV-A Flame-resistant Oil Automation Recycle
Explosion-proof series
EV Explosion-proof Vacuum Purifier
EV-A Explosion-proof Vacuum Purifier
EP Explosion-proof Precision Filtering Purifier
EP-A Explosion-proof Precision Filtering Purifier
sinonsh22@163.com
http://sinonsh22.ec51.com
msn:sinonsh22@hotmail.com
Your inquiries are highly welcome at any time, we are ready to make a response during workdays.
