Centrifugal Pump Minimum Flow
#26
Posted 24 March 2012 - 10:45 AM
When we add the minimum circulation flow to the normal flowrate of the pump when a restriction orifice is present in min. flow bypass line, then do we have to consider the head from the pump performance curves corresponding to the normal flowrate plus the min. bypass flowrate. Will the head change in that scenario?
Pallavi
#27
Posted 25 March 2012 - 01:55 AM
The minimum recirculation flow of the pump should already be included in the pump's normal flow passing the pump, hence the corresponding pump's head would be obtained from the relevant curve. Obviously, the process normal flow would be pump's normal flow minus minimum recirculation flow passing the RO.
Fallah
#28
Posted 26 March 2012 - 10:53 AM
#29
Posted 05 April 2012 - 09:48 AM
Can anyone tell me what is the purpose of providing a globe valve upstream of the restriction orifice in the minimum circulation flow when the purpose of the both the globe valve and restriction orifice is the same.
Thanks in advance
Pallavi
#30
Posted 07 April 2012 - 02:37 AM
Normally in a pump with an almost fixed working point no need to such globe valve, but considering lack of information about the pump operation it just could be said that: 1) probably mentioned pump is working within a range of flowrates and its minimum flowrate needs to be adjusted by a manual globe valve due to changing the operating condition across the RO, 2) the RO is oversized and the minimum flowrate needs to be adjusted .
Fallah
Edited by fallah, 07 April 2012 - 02:41 AM.
#31
Posted 07 April 2012 - 12:35 PM
On confronting the Vendor they said that we are operating the Pump at a higher discharge Pressure than the rated ,which is resulting in low flow.Is this the possible reason.If yes then please suggest me a way out how to eliminate this problem.
Thanks and Regards
Bodhisatya.
#32
Posted 08 April 2012 - 11:59 AM
But the minimum circulation flowrate for a pump is fixed and thus the flowrate through a RO is fixed, so for the constant flowrate do we have to provide a globe valve upstream of the RO.
Pallavi
#33
Posted 09 April 2012 - 12:57 AM
Generally for constant minimum flowrate you don't need to have a globe valve in upstream of the RO. But as i mentioned, if the pump is working within a range of flowrates due to, let say for instance, having two speeds characteristics the minimum flowrate cannot be fixed and might need to be adjusted manually by e.g. a globe valve.
It is just my guess and if you want to have a better input you have to submit the detail information about the pumping system.
Fallah
#34
Posted 09 April 2012 - 02:55 AM
1. The problem with the hydraulic system that you have is that the pump does not match with the system performance curve.
2. This is probably the vendor did not supply the right pump as per your specification or you gave incorrect information to the vendor or there is misunderstanding between you and the vendor.
3. Contractually, the vendor should be responsible to supply you with the correct pump as being specified, therefore it is their responsibility to make corrective action. If the failure is on your side for not giving the right specification, then the vendor can wash their hand.
4. The most common way to resolve this type of problem is to change the pump impeller size, if it is not yet the maximum impeller size.
5. Second option is to increase the line size. However, if the pressure requirement is mostly due to elevation, this option is useless.
Edited by S.AHMAD, 09 April 2012 - 02:58 AM.
#35
Posted 03 August 2012 - 04:30 AM
i want to know about centrifugal pump minimum bypass flow, can you please send me the files to study which were mentioned in the discussions above
1) published in "Hydrocarbon Processing", July 1995.
2) I.Taylor "Pump Bypasses now more important", Chemical Engineering, May 11, 1987, pg. 53.
sahil
#36
Posted 22 September 2013 - 02:42 AM
Can u forward above documents on
Atul
Prevent Flow MaldistributionStarted by Guest_guoyinyanliner_* , 21 Oct 2026 |
Working With Old/paper Pump Performance Curves — How Do You Convert AnStarted by Guest_arundhamodharan_* , 23 Aug 2026 |
Nitrogen Flow Meter Dp Type ErrorStarted by Guest_Ranga v_* , 18 Jun 2026 |
Minimum Distance Between Blowdown Valve And Cold Vent Outlet In A HighStarted by Guest_AMINEBELAL_* , 15 May 2026 |
