Best Practices For Handling 50% Hf – Equipment Failures Issue
#1 Jaydip
Jaydip
Posted 19 June 2025 - 11:42 PM
Hello Everyone,
Glad to connect
We are currently working with the storage and transfer of dilute hydrofluoric acid (50% by weight). However, we often face failures in equipment, valves, and instrumentation due to its highly corrosive nature.
I would be grateful if you could share your insights on how to handle such a corrosive fluid effectively, without compromising equipment integrity or product quality.
we  already use the PTFE coated  pipe line /valves/equipment.
  • 6,937 posts
Posted 20 June 2025 - 01:48 AM
A Google search:
A 50% hydrofluoric acid (HF) solution is highly corrosive and reactive. It's compatible with certain materials for short-term use, but long-term exposure requires careful selection. Materials like Teflon (PTFE), Kynar (PVDF), certain high-nickel alloys (e.g., Hastelloy C-276, Monel 400), and some specialized graphites are suitable for HF vapor service.
#3 breizh
  • 6,937 posts
Posted 20 June 2025 - 06:39 AM
Consider talking to worldwide suppliers like Honeywell international, Solvay, Daikin.
HYDROFLUORIC ACID 49% | Solvay
#4 deft clay
deft clay
  • 19 posts
Posted 20 June 2025 - 10:27 AM
Attached File  Rubber Chemical Compatibility Chart.xlsx   148.65KB   6 downloads
Jaydip, I have a chart I've used for soft goods and material compatibility. This one says that Kalrez is the only suitable material for HF. As usual, verify anything you read in this chart through other resources and vendors!
Edited by deft clay, 20 June 2025 - 10:27 AM.
#5 Jaydip
Jaydip
Posted 24 June 2025 - 08:12 AM
Currently, we use HDPE lining on equipment for storage, and for transferring, we use CS-PTFE lining. However, we still sometimes face failures, such as cracking of the HDPE coating. We want to upgrade our system further. If anyone has experience handling corrosive fluids, we would appreciate your feedback.
