Recommended Installation Location For "pressure High" Interloc
interlock column pressure high
#1 omupei
omupei
Posted 20 June 2025 - 02:34 AM
I am seeking expert advice on the optimal location for a high-pressure switch/transmitter (PAH) that serves as a safety interlock for a distillation column, typically to cut the heat supply to the reboiler.
Based on my understanding, the two primary candidate locations are:
  1. Column Top: In the overhead vapor line or on the reflux drum vapor space.
  2. Column Bottom: Near the reboiler or in the bottom liquid line.
My questions are:
  • Which location is generally preferred as the primary high-pressure trip point and why?
  • How does the choice of location depend on the specific overpressure scenario we are protecting against? For example:
    • For a condenser failure or blocked vapor outlet, is a top-side sensor always superior for faster detection?
    • For a reboiler control failure (runaway heating) or blocked bottoms outlet, is a bottom-side sensor more effective?
  • Is it a common design practice to install high-pressure interlocks at both the top and bottom of the column for comprehensive protection?
  • What is the standard industry practice  for this specific safety-critical interlock?
Thank you for sharing your experience and insights.
  • 6,937 posts
Posted 20 June 2025 - 05:49 AM
These papers are not going to address your specific questions; it intends to address controls on distillation columns.
It may help you.
#3 omupei
omupei
Posted 26 June 2025 - 06:36 AM
It may help you.
Thank you very much for the information.
If you have any additional best practice information regarding the detection point location of the I/L, I would greatly appreciate it.
Edited by omupei, 26 June 2025 - 06:37 AM.
#4 breizh
  • 6,937 posts
Posted 26 June 2025 - 07:25 AM
You should find pointers in the document shared.
