Rising Film Evaporator
heat transfer evaporation boiling
8 replies to this topic
#1 lanco
lanco
  • 4 posts
Posted 23 June 2025 - 02:24 PM
I have to design a rising film evaporator for an organic solution.
Could someone recommend a literature source to calculate heat transfer coefficient inside tubes?
Thanks in advance.
  • 6,942 posts
Posted 25 June 2025 - 02:20 AM
For your application and sensitive products, let you consider those papers.
#3 lanco
lanco
  • 4 posts
Posted 25 June 2025 - 01:28 PM
Thank you Breizh for the information shared.
It is not a difficult evaporation, an agitated film evaporator is not necessary, I think a climbing film evaporator is suitable.
#4 breizh
  • 6,942 posts
Posted 25 June 2025 - 06:07 PM
Let you try our best friend Google; I did not find much.
Reading my old notes (Uni time) I found a reference for vertical tubes, HSU and WESTWATER equation.
h=0.002 *Re^0.6*(lambdav^3*Rov*(Rol -Rov)*g/Muv^2) ^.333
with lamdav =thermal conductivity vapor, Ro density liquid and vapor ,Muv : viscosity vapor.
800< Re <5000
Re calculated at the exit of the pipe based on vapor stream.
As a general rule, heat transfer coefficients are within the range 100 to 250 kcal/h m2 C.
#5 lanco
lanco
  • 4 posts
Posted 26 June 2025 - 02:43 PM
Thanks again.
Edited by lanco, 26 June 2025 - 02:44 PM.
#6 breizh
  • 6,942 posts
Posted 26 June 2025 - 06:07 PM
HI,
The last resource on hands shared with you and others.
Review Chapter 5 Wolverine to support your work. This book was downloadable from Internet years ago.
Key words: Wolverine engineering data book
BTW Did you try Pery's chemical engineers' handbook?
EDIT : Extract from Process Heat transfer Robert W Serth
#7 lanco
lanco
  • 4 posts
Posted 06 July 2025 - 11:35 PM
Thank you so much Breizh
#8 EnggExp
EnggExp
  • 10 posts
Posted 14 July 2025 - 10:35 PM
In Perry’s, Section 5-58 through 5-64 covers boiling and evaporation in vertical tubes, which includes:
• Nusselt’s theory for laminar film condensation (useful as a baseline).
• Heat transfer correlations for vertical tube evaporators, specifically:
h = 0.943 \left( \frac{\rho_l (\rho_l - \rho_v) g h_{fg} k_l^3}{\mu_l L (T_{sat} - T_w)} \right)^{1/4}
For laminar film condensation, but modified for boiling and evaporation using correction factors.
• For rising film evaporators, refer to empirical correlations such as:
\text{Nu} = C \cdot \text{Re}^m \cdot \text{Pr}^n
where values of C, m, and n are given for different regimes (laminar, turbulent, etc.) and flow orientations (upward, boiling, film).
• Section includes detailed tables and graphs for organic liquids, aqueous solutions, and heat transfer coefficients for evaporating flows inside vertical tubes under various conditions.
Special Notes for Organic Solutions:
• Organic fluids often have lower thermal conductivities and viscosities than water, influencing h.
• Perry’s suggests using fluid-specific property tables and adjusting correlations for:
• Viscosity correction factors
• Boiling point elevation
• Wall superheat effects (important in falling or rising film operations)
Where to Look in Perry’s Handbook:
• Table 5-39 through Table 5-41: Properties for various organic and inorganic solutions.
• Section 5-58 to 5-64: Boiling inside tubes and evaporator design.
For a practical and conservative design of a rising film evaporator, use:
• Zuber-type correlations for boiling inside tubes if vapor formation is vigorous.
• Wilson or Chen correlations if you expect significant subcooled boiling followed by annular flow.
#9 EnggExp
EnggExp
  • 10 posts
Posted 14 July 2025 - 10:48 PM
Heat Transfer Coefficient Estimation in Vertical Tubes (Relevant to Rising Film)
Book: Process Heat Transfer: Principles, Applications and Rules of Thumb
From Chapter 9.5:
• Chen correlation:
h_b = S_{\text{CH}} h_{\text{nb}} + F(X_{tt}) h_L
• Includes nucleate + convective boiling
• Uses suppression factor due to flow
• Gungor–Winterton correlation:
Also additive but includes more accurate enhancement factors for boiling number and Lockhart-Martinelli parameter X_{tt}
• Liu–Winterton correlation:
h_b = \left[(S_{LW} h_{\text{nb}})^2 + (E_{LW} h_L)^2\right]^{1/2}
• More accurate for refrigerants and organic fluids
Best fit for your case:
Since you’re working with organic solutions and likely in low-pressure boiling regimes, Liu–Winterton or Gungor–Winterton is recommended over Chen due to broader data fit and better reliability for such fluids .
2. Boiling Regimes in Vertical Tubes
Figure 9.3 and section 9.5.1 describe how fluid transitions through boiling regimes in vertical tubes:
• Bubbly → Slug → Annular → Mist
• Heat transfer increases until dryout, where it drops significantly
• Rising film evaporators should be kept below the mist regime to avoid poor heat transfer
Design Implication:
Maintain moderate vapor fraction and avoid over-evaporation. You want to stay in the annular flow regime, where heat transfer is high but wall drying hasn’t occurred yet.
3. Critical Heat Flux (CHF) Concerns
If you exceed the optimal heat flux, CHF occurs leading to:
• Wall dryout
• Sharp drop in heat transfer
• Possible tube burnout
Palen’s correlation (Eq. 9.84b) gives:
\hat{q}_c = 23,660 \left(\frac{D^2}{L}\right)^{-0.35} P_c^{0.61} P_r^{0.25}(1 - P_r)
Use this to set the upper heat flux limit in your design.
4. Practical Engineering Use
If you lack precise experimental parameters:
• Use Dittus-Boelter for h_L
• Use Cooper or Mostinski for h_{nb}
• Then apply Liu–Winterton for combined coefficient
