Packaging And Gas Velocity In Packed Column
#1 ChemEng_CristianoB
ChemEng_CristianoB
Posted 25 June 2025 - 02:21 AM
Good day to everyone, I am designing an absorption column to remouve methanol from a CO2 stream at 50 bar and 35°C with water.
I have no experience regarding absorption columns, so I would like to ask you for two pieces of advice:
  • generally what velocity should the gas have inside the column (I just need the order of magnitude)?
  • what filling do you recommend? Are IMTPs okay?
Thanks,
Cristiano
#2 Nikolay_
Nikolay_
  • 169 posts
Posted 28 June 2025 - 10:08 AM
Hi, it depends on absorbent flow. Search for how to calculate delta P per hight packing (initinal flooding).
#3 carlos infante
carlos infante
  • 24 posts
Posted 28 June 2025 - 04:49 PM
Fisrt defined the process conditions of absortion
Flow rate  gas and absorbent fluid
Fraction of methanol in the CO@ stream outlet
calcutated the absortion bed requierements and pressure drop
IMTP is a packing normaly used in absortions columns
Carlos
#4 breizh
  • 6,942 posts
Posted 28 June 2025 - 11:10 PM
Consider this resource.
#5 ChemEng_CristianoB
ChemEng_CristianoB
Posted 04 July 2025 - 02:14 AM
Thank you all for the answers.
I have one more doubt to ask.
First let me give you the conditions of the absorption process:
Temperature = 35°C;
Pressure = 48 bar;
CO2 flow rate (containing 1%w/w methanol): 2000 kg/h
Water flow rate: 200 kg/h.
Numeo of theoretical stages: 10.
In this way, according to both the simulator (ChemSep) and my calculations I can achieve effective methanol removal.
Regarding the diameter, following the flooding graphs, I must have a column with a diameter of about 30 cm. With this diameter, the gas velocity (density about 113 kg/m3) is 0.06 m/s.
I know that in an absorption column, to have a good mass transfer the gas velocity must be 0.3 to 0.6 m/s (to which, under my conditions corresponds a column diameter of 10 to 15 cm).
Could it be that working at rather high pressures for an absorption process (and consequently the density of the gas phase has a much higher density) the graphs for diameter calculation give me higher diameter values than necessary?
#6 Nikolay_
Nikolay_
  • 169 posts
Posted 21 July 2025 - 10:07 PM
Why don't you reduce pressure?
