Distillation Column Top Pressure
#1 halkeshhulk
halkeshhulk
  • 25 posts
Posted 27 June 2025 - 01:52 PM
Dear all,
I would like to understand Distillation Column Top Pressure and Pressure in Reflux drum for total condenser. (Debutanizer Column)
Q1. At the top tray where liquid and Vapor are leaving, the top pressure is maintained by the liquid mixture leaving the top tray through its equilibrium Vapor pressure or any impact of Vapor leaving the tray on the top column pressure?
Q2. Once the Vapor gets condensed and gets collected at the top, my reflux drum pressure is also found to be almost same? The pressure in the reflux drum again is due to the liquid mixture Equilibrium vapor pressure?
Q3. I would like to understand, apart from normal flow pressure loss, why normally distillation column top Vapor condensation doesn't bring down the pressure in reflux drum? How to understand it?
Q4. How to understand the pressure concept for any random tray in the column? If liquid Vapor pressure is what is causing pressure, bottom trays contain heavier and the equilibrium liquid vapor pressure should drop due to heaviers in the liquid mixture, but in reality pressure profile is like high at the bottom, from my understanding, it is high due to high temperature of the heavier mixture which has created sufficient equilibrium Vapor pressure more than the light liquid mixture Equilibrium vapor pressure at the top?
Kindly guide me. Love to understand the things properly instead of feeling or saying, that is how it is or it works.
Edited by halkeshhulk, 27 June 2025 - 02:01 PM.
#2 carlos infante
carlos infante
  • 24 posts
Posted 28 June 2025 - 05:18 PM
Top columns pressure is handle by the  temperature in the condense.
Search in google for a distillations textbook  (Kyster)  and read carefully to understand the design bases of distillations columns.
Carlos
#3 breizh
  • 6,939 posts
Posted 29 June 2025 - 01:06 AM
Attached a few documents to support your query.
EDIT: underneath a link to an old good book
Separation Processes, Second Edition
Enjoy the reading.
#4 PingPong
PingPong
  • 1,474 posts
Posted 29 June 2025 - 12:23 PM
I have designed many distillation columns in my life, so I know how it's done.
Every distillation column has a pressure controller (PC) that maintains the column pressure at its set point. A debutanizer has the PC usually installed on the reflux drum.
In case of total condensation the PC controls the cooling medium used in the condenser, or a hot vapour bypass around the condenser.
The designer of the debutanizer has determined that setpoint, following a few steps:
(1) Take a look at the design feedstock composition.
(2) The distillate of a debutanizer will consist of the C4 and lighter components of that feedstock.
(3) Take a look at the available utilities to be used as a cooling medium in the condenser: depending on the rest of the plant these can be ambient air, cooling water, chilled water, refrigerant, ...........
(4) We will assume here that the designer selects cooling water, available at a temperature of say 30 oC.
(5) Assuming the cooling water warms up from 30 to 40 oC in the condenser, the condenser outlet temperature can be 40 - 45 oC, depending on the exact composition (especially the amount of C3 in it) of the distillate. Let's assume 45 oC.
(6) Now the designer does a Bubble Point Pressure calculation of the distillate composition of step 2. That gives the required pressure in the reflux drum, and therefore the setpoint of the PC.
(7) The debutanizer column top pressure will be say 0.3 bar higher than the reflux drum pressure due to frictional pressure loss over condenser and associated piping.
(8) The debutanizer column top temperature can then be found by a Dew Point Temperature calculation of the distillate composition (from step 2), as in case of total condensation (which you mentioned) the distillate product, the reflux and the column vapour overhead all have the same composition.
(9) The bottoms product of the debutanizer will consist of the C5 and heavier components in the design feedstock.
(10) The debutanizer bottoms temperature, which is the reboiler outlet temperature, is then determined by a Bubble Point Temperature calculation of the bottoms product from step 9 at a pressure that is say 0.3 bar (to account for pressure drop over the trays in the column) higher than the column top pressure.
(11) Now the designer takes a look at the available utilities for use as a heating medium in the reboiler: steam, hot oil, a pump-around from one of the other distillation columns in the plant, ...............
(12) Obviously the selected heating medium has to be able to provide a temperature high enough to achieve the required reboiler outlet temperature determined in step 10. If none of the available utilities meets that requirement, a fired heater would be required as a reboiler.
(13) Usually nobody likes to have a fired reboiler, so in that case the process to determine the column pressure has to be reversed by starting with selecting a lower bottoms pressure that results in a lower bottoms temperature that can be achieved by the preferred heating medium.
(14) In that case also the reflux drum pressure will have to be lowered, resulting in a lower condenser outlet temperature, and then the selection of the cooling medium in the condenser has to be redone.
(15) Once all pressures have been set by the above steps, the designer simulates the column using a process simulator like Aspen Plus or Hysys or PRO/II or ..........
You could use freeware like DWsim.
Note that all the above is the procedure for total condensation of the distillate. In case of partial condensation (mixed distillate), or in case of a vapour distillate the procedure is somewhat different.
Answer to Q1, Q2, Q3 & Q4: the reflux drum and column top pressures are simply as I described above in step 7, no need to worry about equilibria or condensation or whatever inside the column.
Edited by PingPong, 29 June 2025 - 12:26 PM.
