Hello, can the allocation of steam in the shell side of a vertical heat exchanger cause corrosion problems ? Due to excessive vibration, I had to allocate the steam on the shell side and changing to a floating head to cover the thermal expansion... just want to know the negative aspects of this choice. Thank you
Steam On Shell Side Of A Vertical Hex
Started by Lyne, Jul 09 2025 04:35 PM
No replies to this topic
Posted 09 July 2025 - 04:35 PM
Velocity In A Vertical Pipe Or Open PipeStarted by Guest_jango_* , 02 Dec 2025 |
