Radar Level Instrument
instrument radar isolation valve storage tanks
7 replies to this topic
#1 Lyne
Lyne
  • 60 posts
Posted 24 August 2025 - 02:56 PM
Hello, please does a radar level instrument installed on a storage tank require an isolation valve ?
Edited by Lyne, 24 August 2025 - 02:57 PM.
  • 1,639 posts
Posted 24 August 2025 - 03:39 PM
I have seen many storage tanks open to the atmosphere without any isolation valves! Isolation valves might be required if the contents need to be isolated.
#3 breizh
  • 6,942 posts
Posted 24 August 2025 - 06:11 PM
Hi.
No isolation valve. Check documentation from Vega or other vendors .
#4 Lyne
Lyne
  • 60 posts
Posted 24 August 2025 - 11:47 PM
Many thanks for your answers
#5 Lyne
Lyne
  • 60 posts
Posted 24 August 2025 - 11:52 PM
But if it’s a pressure transmitter it’s equipped with an isolation valve!
#6 breizh
  • 6,942 posts
Posted 25 August 2025 - 03:32 AM
If your tank is breathing to atmosphere, there is no need for isolation valve.
Radar technology is reliable; isolation valve may be required for technology subject to maintenance.
I've been using intensively this technology in chemical plants, on storage tanks reactors, buffer tanks, I don't remember Isolation valve installed.
Other reference E&H attached
Good luck.
#7 Pilesar
  • 1,639 posts
Posted 25 August 2025 - 07:21 AM
Can the level device be maintained safely while the storage tank is in service? If the storage tank contains lethal or highly hazardous substance, then I advise a block valve. Could you defend not having a block valve if the question were asked during a HAZOP study?
#8 Lyne
Lyne
  • 60 posts
Posted 30 August 2025 - 01:01 AM
It’s an oil storage tank open to atmosphere,
thank you everyone
