Vacuum Pump
#1 R.t
R.t
  • 3 posts
Posted 19 September 2025 - 07:50 AM
if i have to reduce the pressure of a separator and want to use a vaccum pump for reducing it, should it be installed before the separator or after the separator
  • 1,639 posts
Posted 19 September 2025 - 04:42 PM
Vacuum pumps are most effective when they pull a vapor stream. Typically they are placed after liquid is separated. Often a condenser is used upstream of the vacuum device to remove additional mass as condensed liquid in order to reduce the load on the vacuum pump.
#3 fallah
  • 5,026 posts
Posted 19 September 2025 - 10:01 PM
General question will lead to a general response:
You are reducing the pressure of the separator itself; hence the vacuum pump should be installed on the separator (neither before nor after) but such that leading to minimum interfering with separation and not to draw the separated products (mostly vapor) as much as possible...
#4 breizh
  • 6,942 posts
Posted 20 September 2025 - 01:09 AM
My experience with vacuum pumps, they hate liquid, in particular dry vacuum pump type !
You should install it on gas stream after condenser.
