Hello everyone,
Could you please share with me any document or your help with sizing a condensate return vessel?
Posted 23 October 2025 - 10:32 AM
Hello everyone,
Posted 23 October 2025 - 02:08 PM
Hello everyone,
Liquid condensate mass flow rate (kg/s) = mass flow rate (kg/h) ÷ 3600
Required mass stored (kg)= mass flow rate (kg/s) × retention time (s)
Vessel volume (m³) = mass stored (kg) ÷ liquid condensate density (kg/m³)
Returned vessel diameter can be obtained from vessel volume with supposing a height for the vessel...
Note: Typical retention time for normal service is 5-10 minutes
Posted 23 October 2025 - 09:45 PM
I think you got your answer.
t=V/F, t time, V useful volume, F flow rate
References to consider: Perry and GPSA
my 2 cents
Posted 24 October 2025 - 01:55 AM
Thank you both for your responses. I have a question regarding steam condensate lines: if I have two streams at different pressures—7 barg and 3 barg—feeding into a common condensate vessel, are these typically combined before entering the vessel, or should they be routed separately?
Additionally, should I consider the possibility of flashing within the vessel?
Posted 24 October 2025 - 04:01 AM
you should separate the lines otherwise it will affect the flows to the tank. Yes, flash will occur in the pot.
Posted 25 October 2025 - 06:37 AM
Thank you Breizh for your reply.
Conceptual Sizing Of Adsorber ColumnStarted by Guest_JJvdM_* , 24 Oct 2019 |
Separator SizingStarted by Guest_HOTTEST_* , 12 Mar 2026 |
