Hello everyone,
I’m currently working on a lean glycol cartridge filter that contains about 98% TEG and 2% water. The client is insisting on a PSV for the fire case, and I’m struggling with some practical aspects of this requirement.
When I model the fire case, the relieving temperature comes out to be around 900°F, which is extremely high compared to the vessel design temperature of 250°F. The set pressure is 1330 psig, while normal operating pressure is about 895 psig.
I do understand from API 521 that the relieving temperature can exceed the vessel design temperature under fire exposure. However, this value still seems unrealistically high, and I believe it’s because I’m forcing vaporization of a very stable, high-boiling liquid (TEG) under high pressure.
This raises a few concerns:
Thermal degradation: TEG starts to degrade well below the calculated relief temperature. So should decomposition or combustion be considered before actual vaporization? If glycol is already degraded at such temperature, then what phase (liquid/vapor/decomposed product) will the PSV actually relieve?
Liquid-filled vessel: The client expects the vessel to remain completely liquid-filled, meaning the relief under fire should primarily be liquid expansion, not vapor generation.
API 521 approach: Can I simply calculate the heat absorbed (Q = C × F × A⁰·⁸²) and use it only to account for thermal expansion of liquid from operating temperature up to the boiling point, without extending into the vaporization zone?
I’m trying to determine a realistic and code-compliant approach for sizing the PSV in such a non-flashing, high-boiling liquid system.
Fire Case Psv For Lean Glycol Filter
Started by Arsalan_1992, Nov 08 2025 03:28 PM
Posted 08 November 2025 - 03:28 PM
Posted 09 November 2025 - 09:51 AM
Refer here:
https://webbook.nist...12276&Mask=3EFF
and review your relieving conditions against the fluid's critical point.
The PSV's relieving pressure far exceeds the critical pressure of TEG. You'll need to adjust your methodology to assess for a fluid that is above it's critical point. It's not a simple latent heat / boiling liquid / wetted surface area analysis.
Feel free to point out any flaws in my thinking.
All the best.
All the best.
Two Phase Reverse Flow -Psv Sizing For Check Valve Failure CaseStarted by Guest_namita.modak1_* , Yesterday, 08:15 AM |
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
Sizing And And Process Control Of Filter PressStarted by Guest_Amalina Jamil_* , 11 Mar 2019 |
Is Emergency Venting Required For Polyethylene Storage Tank In Fire ScStarted by Guest_chem55_* , 01 Aug 2025 |
