Spray Dryer Nozzle Issue – Pressure Increase And Fines Increase
Started by Ella2365, Mar 24 2026 02:48 PM
Posted 24 March 2026 - 02:48 PM
This started without any process or concentrate changes.
We are experiencing an issue in a spray dryer system (MPC):
- Pressure to nozzles increased from 130 bar to 160 bar without any process changes
- Significant increase in fines, confirmed by sieve analysis in the laboratory
- As a result, solubility index increased from 0.9 ml to 3.5 ml
- Hoses and orifices/swirls have already been replaced
We suspect a possible partial internal blockage in the nozzle lance. From programme graphics it is not possible to decide which one lance is struggling. High pressure pump is working properly.
Questions:
1. Have you experienced internal clogging causing higher atomization (more fines)?
2. What practical methods do you use to verify clogging without visual inspection?
Any experience with milk protein (MPC) systems would be highly appreciated.
Questions:
Posted 24 March 2026 - 05:52 PM
This should be part of the process description and process validation. I believe your process is under cGMP and atomization pressure should be one of the key parameters of your process.
Good to review the documents supplied with the equipment and or ring the equipment's supplier.
Particle Engineering using Spray Drying and Fluid Beds
Note: Comments based on my experience using fluid bed dryer to produce paracetamol.
The Basis Of Calculation To 3% Pressure Loss At The Inlet Of PressureStarted by Guest_phoenixmoca_* , 14 Mar 2026 |
Mdmt Basis For Gas Let-Down From High-Pressure Storage (Non-Blowdown CStarted by Guest_naghizad_* , 27 Feb 2026 |
Organic Peroxide Distillation IssueStarted by Guest_Kimbreaux_* , 19 Feb 2026 |
Flow & Pressure Regulation For Compressible FluidsStarted by Guest_Abdessamed1961_* , 14 Dec 2025 |
