2
Agitator Calculations
#1 Biomass Process
Biomass Process
  • 15 posts
Posted 04 June 2026 - 02:03 AM
Can any body having agitator performance calculation sheet -to calculate pumping flow rate ,power number ,tip speed,pumping number
  • 7,058 posts
Posted 04 June 2026 - 06:58 AM
Don't be lazy!
If you google the definitions, you should be able to produce your own calculation sheet. This is the way engineers work.
I've attached documents to support your query.
Mixing Calculators | CheCalc
#3 Biomass Process
Biomass Process
  • 15 posts
Posted 05 June 2026 - 06:54 AM
Thank you very much  for sharing excel sheet .
Edited by Biomass Process, 05 June 2026 - 06:56 AM.
