2
​"natural Gas Co2 Removal Via Membrane Separation
#1 guoyinyanliner
guoyinyanliner
  • 80 posts
Posted 10 June 2026 - 07:18 PM
Natural gas CO2 removal via membrane separation: The feed gas enters a shell-and-tube heat exchanger to be heated to 35°C by hot water before entering the 1st-stage permeation membrane. The separated permeate gas is compressed and sent to the 2nd-stage membrane separation, after which the retentate/residue gas is recycled back to the inlet, while the 2nd-stage permeate gas is sent to the generator set for power generation. Is anyone familiar with this P&ID? Are there any control flow diagrams available? I would like to study which points require enhanced control
  • 7,055 posts
Posted 11 June 2026 - 06:24 PM
SEPURAN® NG – Gas separation membrane technology for efficient natural gas processing | Evonik
Check with Evonik China , you may be able to visit industrial sites.
Locations in China and contacts - Evonik Industries
#3 guoyinyanliner
guoyinyanliner
  • 80 posts
Posted 11 June 2026 - 11:45 PM
thanks ,i want ,the Process Flow Diagram (PFD) for Membrane Separation Unit with Control and Safety Interlocks
#4 breizh
  • 7,055 posts
Posted 12 June 2026 - 12:13 AM
Simulation on acid gas removal from natural gas processing with membrane and absorption process
Consider this resource above to develop your PFD. We may be able to comment.
Don't expect forum members to share with you companies' documents.
Good luck.
#5 guoyinyanliner
guoyinyanliner
  • 80 posts
Posted 12 June 2026 - 09:24 PM
Good luck.
thanks ,It's so hard
#6 breizh
  • 7,055 posts
Posted 12 June 2026 - 11:32 PM
Get contact with membrane suppliers, they should be able to support if you have a project moving forward.
Note: Process lead within your organization should help you.
b: Hysys process flow diagram for 3-stage (Case B) membrane integrated... | Download Scientific Diagram
   pdf file.
Good luck.
#7 guoyinyanliner
guoyinyanliner
  • 80 posts
Posted 16 June 2026 - 06:44 PM
pdf file.
Good luck.
谢谢
