What Factors Should Be Considered When Optimizing Cement Grinding Aid
Posted Today, 03:16 AM
Posted Today, 04:05 AM
The optimum grinding aid dosage depends largely on the actual mill conditions. Clinker grindability, cement fineness, separator efficiency, ventilation and cement temperature should all be considered.
For blended cement, such as slag or fly ash cement, the optimum dosage can also be different from OPC. In practice, it is better to test several dosage levels and compare mill output, fineness, power consumption and cement strength.
For reference, some suppliers such as SHENGCHUAN also develop grinding aids for OPC, slag and composite cement applications: https://www.shengchuanintl.com
Posted Today, 04:06 AM
Another factor worth considering is that the optimum dosage can vary significantly between cement types and raw materials.
For example, slag and fly ash often behave differently from clinker during grinding, so simply increasing the dosage may not improve performance. A small plant trial with several dosage levels is usually the best way to determine the most economical dosage.
We have seen this approach used with different grinding aid formulations for OPC, slag and composite cement. More information on these applications can be found here: https://www.shengchuanintl.com
Posted Today, 05:28 AM
Stop using this platform to support your business otherwise you will be banned.
Posted Today, 05:34 AM
Guidelines / Rules for Posting
6. No advertising or recruiting of any kind will be tolerated. Your posts will simply be deleted and you'll be banned from further posting.
Relief Path To Be Considered For Inlet Pressure Drop CalculationStarted by Guest_Ascanio E._* , 09 Jul 2025 |
Design Margins Instead Of Fouling FactorsStarted by Guest_Vegeta_* , 12 Dec 2023 |
Grinding Type Vs Particle SizeStarted by Guest_kangas_* , 14 Oct 2020 |
Designing Pilot Plants, Factors While Experiment DesignStarted by Guest_ChinmoyBasak_* , 12 Aug 2020 |
Carbon Dioxide In Cement ManufacturingStarted by Guest_Mohammed Al-fakhry_* , 21 Nov 2019 |
