Nru
Posted 24 November 2026 - 09:51 PM
Posted Yesterday, 03:13 AM
Consider this link to support your work:
Introduction to double-column Nitrogen Rejection Unit NRU
Check also with Google, keys words Nitrogen rejection unit
Should be a PIC ,no?
Should be the result of simulation?
my 2 cents
Posted Yesterday, 04:26 AM
For in the LNG process, the Nitrogen Rejection column or End Flash Drum - probably has many other names to aid in your searches.
The valve before the column (between the MCHE and the Nitrogen Rejection Column) provides back pressure on the MCHE and flashes the LNG down to the Nitrogen Rejection Column pressure. The JT across this device will do the final subcooling of the LNG.
Some LNG designs will have an liquid expander in combination with the valve. The valve provides some backpressure to the expander to reduce flash at the expander.
As it provides back pressure, to the MCHE the NRC pressure can be controlled as you have described.
If you have a PFD or sketch of the arrangement its always helpful to include to make sure we all understand each other.
Hopefully i have explained the correct valve.
Posted Yesterday, 06:20 AM
Sorry, I'm not sure how to paste/attach an image here
Posted Yesterday, 06:33 AM
Use a PC.
In the "Reply to this topic" window, click "More Reply Options".
Below the new window, you'll see "Attach Files".
Use "Choose File" to choose your files.
Then, use "Attach This File" to attach your files into the post.
Posted Yesterday, 11:14 AM
The feed valve to the column inlet should be located at the elevation of the column nozzle. You do not want flashing before the valve. The liquid before the valve should be subcooled and the line routing should be designed so that there are no high pockets.
Posted Yesterday, 08:17 PM
补充图片
Posted Yesterday, 08:29 PM
Congratulations!
Posted Yesterday, 08:36 PM
#10
Posted Yesterday, 09:42 PM
Not sure but the pressure on scheme A should be controlled after the PCV! You need to drop the pressure through the valve meaning your set point is on the low side of the valve.
Note: Make sure you have a way to protect the column in case of PCV failure ( open)
Posted Today, 08:50 AM
Nitrogen rejection units can be located in the front-end, tail-end or integrated within the cryogenic plant. Depending on the requirements, the NRU may have one, two, or three columns. The control scheme depends on which columns are intended and where they are located in the plant. You may want to research NRU processes in general to get an understanding of the purpose and function of the equipment and how it fits into the process.
#12
Posted Today, 07:54 PM
→ I just mean the control of that control valve
#13
Posted Today, 07:55 PM
I've attached the image
