Dear all
In our refinery as I suppose in many other refineries we are short for i-C4 as feed to alkilation unit. As I know for C4 alkylation unit, ratio of C4 olefins an i-C4 is about 1:1.2 respectively. And we run our alky unit in that manner, it is sulphuric acid alky unit.
During discussion with some of my colleagues they mentioned that is possible to run alky unit with ratio C4= to i-C4, 1 : 0.9 respectively. In my opinion it is not possible, because if we have ratio 1 : 0.9 we will consume i-C4 cooling media, and i-C4 recycle from disobutaniser column.
What is your opinion?
Milutin
Alky Unit
Started by Milutin, Dec 29 2006 01:43 PM
Posted 29 December 2006 - 01:43 PM
Posted 12 March 2009 - 12:26 PM
QUOTE (Milutin @ Dec 29 2006, 08:43 PM) <{POST_SNAPBACK}>
Dear all
Milutin
Milutin
Posted 17 March 2009 - 11:50 AM
To bypass the deisobutanizer tower - but where? As you know, you can't send unstabilized alkylate to storage tanks. I'm not sure if I understood your post, and I am very much interested if you can elaborate a little bit further on the topic.
Best regards,
Posted 17 March 2009 - 02:04 PM
As I understand Mr. npopov, deisobutaniser feed can be bypassed and bypassed stream can be sent only back to reactor, because of high concentration of isobutane and n-butane.
But in my opinion this will not solve problem if concentration of i-C4 on unit inlet is less than normal (C4= to i-C4 1:1.2).
![]() Fixed Bed Absorber Tsa UnitStarted by Guest_Sufy_* , 13 Mar 2025 |
![]() ![]() Molecular Sieve UnitStarted by Guest_Sufy_* , 26 Feb 2025 |
Basic Dynamic Simulation Of A Crude Distillation UnitStarted by Guest_tomr91_* , 12 Jan 2025 |
![]() Vacuum Getting Disturbed Periodically In Vacuum UnitStarted by Guest_aka28_* , 08 Oct 2024 |
