Details
Local wheather condtion
WBT- 23 C (max) 18 C (min)
DBT-36 C (max) 32 C (min)
water circulation rate - 8000 m3/hr
Angle-9 degrees
Aproach- 7 C (design) 17-18 C (Actual what we are getting)
Sump/reservior level - 2500 m3
Nos. of fans - 3 (induced draft cooling tower)
(gear ratio motor rpm: fan rpm = 1:11)
We have V-bars of Polypropylene the dimensions are
1000 X 45 degrees X 50 X 50 mm
Cooling water pH- 7.4 (Supply to process and 7.8 of cooling water inlet to cooling tower)
So please if anyone is having good idea of cooling tower or the same experiance of the same i request you to come forward and suggest the solution for the same
