As you know one of the most important blocks in simulators environment are columns.
In order to converge column blocks we need to adjust some specs to set the degree of freedom to zero.
The degree of freedom formula for a column is:
(No. of Products)+(No. of Energy Streams)-(No. of Aqoues Products)-2
Open steam streams should not be included in energy streams.Also for columns with side strippers the outlet steam from these stippers should not be included in product streams.
Who knows about the concept behind of this formula?
Thanks in advance.
Cheers.
Degree Of Freedom For Columns
Started by jprocess, Feb 14 2007 12:51 AM
No replies to this topic
Posted 14 February 2007 - 12:51 AM
Dew Point Margin In Strippers & Fractionation ColumnsStarted by Guest_Venkat @89_* , 05 Sep 2023 |
Startup The ColumnsStarted by Guest_ali99_* , 02 Jan 2023 |
Degree Of Freedom In Distillation Column And Absorption ColumnStarted by Guest_lnbsak_* , 21 Jul 2021 |
Pressure Drop Across Trayed ColumnsStarted by Guest_sharonlae_* , 23 Mar 2019 |
How To Find Degree Of Superheat For SteamStarted by Guest_Rahul Maurya_* , 29 Nov 2018 |
