What is the maximum rate of chlorination that can be achieved with a chlorination tonner?
Maximum Chlorination Reate?
Started by ASH25320, Feb 25 2007 01:51 AM
Posted 25 February 2007 - 01:51 AM
Posted 05 March 2007 - 07:55 AM
ASH
I am not expert in this field but still I am going to give my first answer in this forum as follows:
You have not specified the line size. as you know that effect of temp. on its vapor pressure like at
-33deg.C vapor pressure of chlorine is about 1 atm. and at 27deg. it is around 8 atm. (~8.1 bar).
Generally chlorine tonner have capacity of around 900 to 950 kgs of chlorine and 5/8" of outlet valve (I am not sure what kind of tonner u r using). So the chlorination rate is fully depends on what pressure you are maintaing at the outlet by considering valve opening at the outlet of chlorine tonner and the flow pass thro' it.
Try to solve your problem considering above point you may get the answer.
Maximum Natural Gas Flow Through OrificeStarted by Guest_ukrche_* , 10 May 2024 |
Maximum Nozzle Size In The Api 650 TankStarted by Guest_rudiawan_* , 18 Oct 2023 |
Maximum Number Of Regeneration Cycles In Mole SieveStarted by Guest_YouAB_* , 23 Apr 2023 |
Maximum Inflow To Sourwater Feed Preparation TankStarted by Guest_Francis philomenraj_* , 23 Feb 2023 |
Maximum Vessel Wall Temperature For Fire (Gas Expansion) CaseStarted by Guest_yog123_* , 14 Dec 2022 |
