We have been having to treat our propane occasionally because it fails the Copper Strip Corrosion Test. We have been using an H2S scavenger, assuming it is H2S that causes it to fail.
Sometimes this works as expected and sometimes it does not. Sometimes a tank will be bad, we will circulate it overnight, pumping in the scavenger through the night, and the tank will test good the following day.
But then later the same day or the next day it will fail the Copper Strip Test again, even though nothing more was added to the tank.
Are there other compounds that can cause a bad copper strip test? Are they all sulfur compounds? Are there other substances that might work in conjunction with H2S to cause it to fail? Would Oxygen make it worse?
"sour" Propane
Started by Guest_coltech2_*, Nov 11 2003 11:24 PM
Guest_coltech2_*
Posted 11 November 2003 - 11:24 PM
Posted 13 November 2003 - 05:12 PM
Carbonyl sulfide (i.e., COS) and mercaptans (i.e., RSH) do not tarnish copper by themselves. However:
(1) COS in the presence of water will slowly hydrolyze to form H2S which will tarnish the copper.
(2) Mercaptans in the presence of any organic acids will tarnish copper.
Has your LPG been treated with Merox or any other process for removal or conversion of mercaptans?
I suggest you contact the Petrolite division of Baker Hughes at:
http://www.bakerhugh...2R_Brochure.pdf
They may be able to help you.
Selection Type Of Heater For Refrigerated PropaneStarted by Guest_livetolove003_* , 07 May 2025 |
Propane Loss From Sphere TankStarted by Guest_rasprocess2026_* , 04 Nov 2024 |
Propane Product Temperature Correction FactorStarted by Guest_loggrrr_* , 20 Nov 2023 |
Hydrocarbon Dew Point Control Using Propane Refrigeration Loop.Started by Guest_BabRafiq1_* , 10 Jul 2023 |
