Helloo Everyone,
could you give a precise definition about the difference between the steady-state simulations and dynamic ones. Thanks in advance.
Difference Between Steady-stade And Dynamic Simulations.
Started by tonywen, Apr 13 2007 04:33 AM
Posted 13 April 2007 - 04:33 AM
Posted 17 April 2007 - 06:26 AM
QUOTE (tonywen @ Apr 13 2007, 10:33 AM) <{POST_SNAPBACK}>
Helloo Everyone,
A Steady State simulation does not consider the effects of time. It assumes that the plant has reached steady operating conditions. This is best suited to answer questions like "if I want to get a certain pressure/flowrate in one part of the plant, how big should my valve be - or, if I want to get a certain composition in a part of the plan, how much of stream X should I add". This is frequently used to work out the duties of bits of equipment.
A Dynamic simulation does consider the effects of time. It assumes that the plant is in a state of change. This is better suited to answer questions like "if my compressor trips (fails, shuts down) how will my plant deal with it". We often use dynamic simulations to test different control strategies, by introducing disturbances or other problems to the plant, and seeing how well the controllers deal with the problem.
Hope this helps,
- Steve.
Dynamic Simulation - SeparatorsStarted by Guest_tomr91_* , 10 Mar 2025 |
Converting A Static Simulation To Dynamic SimulationStarted by Guest_tomr91_* , 26 Feb 2025 |
Basic Dynamic Simulation Of A Crude Distillation UnitStarted by Guest_tomr91_* , 12 Jan 2025 |
![]() Static Simulation To Dynamic Simulation Of CduStarted by Guest_tomr91_* , 09 Jan 2025 |
