Hello again.
I got another HYSYS problem again.
I have a pipe segment that I have deigned in hysys. I got the pipesize, elevation and length of the pipe, and it is giving me proper values in steady state mode. But when I switch to dynamic mode and start the integrator, the pressure drop gets lower?
I steadystate i got 180 bar pressure loss in the segment, that consists with my own calculations, but in dynamic mode I get 70 bar pressure loss.
kind regard
KurtO
Pipe Segment In Hysys
Started by , May 10 2007 07:29 AM
Posted 10 May 2007 - 07:29 AM
Posted 11 May 2007 - 11:09 AM
It's hard to verify what your problem is, but there seems to be a number of issues especially with holdup calculations in versions prior to Hysys 2004. What version are you using, and do you have single phase or two-phase flow?
Posted 12 May 2007 - 10:21 AM
Hi Joerd
And ty for your reply.
I got a flow that consists of water and liquid hydrocarbons, a two phase flow.
I am running hysys version 2004.2
If u need additional information let me know
KurtO
KurtO
Gas-Liquid Pipe Flow Friction Loss CorrectionStarted by Guest_Huba_* , 18 Dec 2025 |
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
Velocity In A Vertical Pipe Or Open PipeStarted by Guest_jango_* , 02 Dec 2025 |
