I need help sizing a steam line. the source of steam is from a tank operating under pressure. the steam is flashing from the tank. the tank pressure can be varied. typical pressures at which steam is flashing is between 25 - 50 psig. and temp from 130 C to 147 C
i need to design a steam line to support flows up to 12000 lb/hr at the lowest pressure of 25 psig. and flows of up to 9500 lb/hr at the intended operating pressure of the tank of 35 psig.
the estimated pipe length where the steam to be delivered is about 600 ft.
i need help in choosing the best pipe size that can operate at the above operating conditions.
what method can i use to determine the best pipe size?
Steam Line Sizing
Started by CheGuy, Jun 07 2007 07:22 PM
Posted 07 June 2007 - 07:22 PM
Posted 08 June 2007 - 05:32 AM
You posted this question in the Industrial Professionals Forum. Please do not multi-post. If you are a student, this is where the post needs to be. If not, then it belongs in the Industrial Professionals Forum. IT DOES NOT BELONG IN BOTH.
![]() Separator Sizing Step By Step ProcedureStarted by Guest_krishnamurthy_* , 06 Apr 2023 |
Ammonia Line Vapor GenerationStarted by Guest_simadri_* , 07 Apr 2025 |
