-------------Original Message--------------
I am attempting to understand the heat generation problem during the compression of nitrogen. Is this problem attributable to the heat capacity ratio (1.4) of nitrogen? (If so, how does the heat capacity ratio increase with increasing pressure?)
--------------Response----------------------
The compression of any gas results in raising the temperature of the gas ... this is not unique to nitrogen. The adiabatic compression of a gas follows this equation:
T2 / T1 = (P2 / P1) (k -1) / k
where: k = the heat capacity ratio
I would also point out that many gases have a heat capacity ratio
in the range of 1.3 to 1.4 ... again this is not unique to nitrogen.
Hope this helps,
Milton Beychok
(Visit me at www.air-dispersion.com)
Nitrogen Compression
Started by Chris Haslego, Apr 08 2003 06:32 PM
No replies to this topic
Posted 08 April 2003 - 06:32 PM
Nitrogen Capacity Tankfarm During WinterStarted by Guest_jango_* , 03 Feb 2025 |
![]() Nitrogen Leak Test On PipeStarted by Guest_mesbah_* , 24 Oct 2024 |
![]() Most Feasible And Economically Friendly Nitrogen Supply For Tank BlankStarted by Guest_Godwin Anyimah_* , 27 Sep 2024 |
![]() Using Feed Compressor For Start-Up Nitrogen CirculationStarted by Guest_behrouzifar_* , 06 Sep 2024 |
Nitrogen RequirementStarted by Guest_Ali4269278331_* , 05 Jun 2024 |
