Per the latest Norsok Standard Edition 5, September 2006, maximum vellocities for flare headers and sub-headers have been restricted to Mach 0.6.
Some other standards also mention a maximum velocity of Mach 0.7 and Mach 0.8.
One standard in fact mentions an even lower velocity of Mach 0.5 for the flare main header in view of accomadating future expansions/debottlenecking
Also some standards mention sizing only in terms of the momentum Rho X V2. Norsok mentions restricting momentum to less than 200,000 kg/ms2
Even for the momentum criteria some standards have given lower values then given by Norsok.
I would think that the momentum or velocity criteria would also have relation to the line size.
I am confused by this conflicting datas. I would request an expert to give some answers regarding this matter.
regards,
ankur2061
Flare Header And Sub-header Maximum Velocities
Started by ankur2061, Jul 24 2007 02:28 PM
No replies to this topic
Posted 24 July 2007 - 02:28 PM
Temp Of Flare Header For Stress AnalysisStarted by Guest_Araboni_* , 20 Jul 2026 |
Nitrogen Purge On Flare StackStarted by Guest_sanderson51_* , 08 May 2023 |
Verificación De Subcolector De Venteos En Aspen Flare Analyzer V14Started by Guest_Sil_Ben_* , 26 Jun 2026 |
Thermal Oxidizer HeaderStarted by Guest_ryn376_* , 29 Jan 2026 |
Flare Header Reverse FlowStarted by Guest_Ahmadhamzahperta_* , 04 Apr 2025 |
