Can you please provide me the complete material class for the P&ID Line designation.
Say P-10033-A1f-100-IH.
Here what A1f represents?
And can anyone provide the complete list of this specification.
Thanks and Regards,
P.Sridhar.
P&id Line Designation
Started by Sridhar P, Jul 27 2007 04:13 AM
Posted 27 July 2007 - 04:13 AM
Posted 27 July 2007 - 05:18 AM
There is no standard for piping material class designation for P&IDs. Piping material class designation is totally and 100% company-specific. I work for an E&C company, and I have three different client P&IDs sitting in front of me with three very different piping material class designation for the same material pipe.
Posted 31 July 2007 - 05:27 AM
Thank you sir for your valuable feed back.
Thanks and Regards,
P.Sridhar
Thanks and Regards,
P.Sridhar
Posted 25 May 2012 - 05:17 PM
P&ID Legend Sheet should tell you information, you also can check process or pipe design criteria from your project
Posted 26 May 2012 - 12:55 PM
Sridhar,
Agree with pleckner [above] that there is no as such rule for line tag numbers BUT a line tag number should give you loads of information/data.
I would prefer a line tag number as shown below. This just an example - you can use your own short forms and terminologies but the line tag number should give loads of information. I really don't see any point when people use line tag number as 80SS or 80NB.
WTP-D80-001-CAU-CS-ET-25MW
where,
WTP - designation given to the plant where the line is located - here I have used WTP [waste treatment plant]. You can use your own short forms
D80 - pipe nominal bore size - here D80 is 3" diameter
001 - unique line number i.e. each line should have unique identifying or sequential number - here i have used 001
CAU - material content - here CAU is caustic. You can use your own short forms
CS- material of construction of pipe - here CS is carbon steel
ET - type of heat tracing if applicable - here ET is electrical tracing. If you do not have heat tracing, you can leave it blank or use 'NO'
25MW- thickness and type of insulation if applicable - here 25MW means 25mm thick mineral wool insulation. If you do not have insulation, you can leave it blank or use 'NO'
Therefore, normally we issue a 2-3 page document [decoder] to go with P&IDs wherein you can find what short form/identifier is used for what. In your case, you should ask your colleague/client if they have got such document.
Hope, this helps!
KS
where,
Hope, this helps!
KS
Edited by chemks2012, 26 May 2012 - 01:03 PM.
Posted 27 May 2012 - 04:08 AM
Sridhar,
http://piping-design...ine_Designation
For example ,
Companies have their own standards Equipment numbering System for Piping line numbering system you can have code for each Alphabets or Numbers.
Shivshankar
For example ,
Shivshankar
Ammonia Line Vapor GenerationStarted by Guest_simadri_* , 07 Apr 2025 |
![]() Flow Through Normally No Flow LineStarted by Guest_iippure_* , 08 Apr 2025 |
Inlet Line Not Free DrainingStarted by Guest_Asifdcet_* , 07 Apr 2025 |
