i am modeling a multicomponent tower with liquid sidestream in Aspen plus. i keep getting an error saying the stages from the liquid side stream to the feed are dried up. does anyone know how to troubleshoot that?
Aspen - Stages Get Dried
Started by CheGuy, Aug 05 2007 10:25 AM
Posted 05 August 2007 - 10:25 AM
Posted 05 August 2007 - 10:52 AM
It is possible that tower material/heat balance cannot be closed with the specifications and/or feed parameters that you have as model inputs. From your statement, internal reflux is practically = zero, at points below the side-cut location.
Reducing the sidestream draw-off rate might be of some help in further troubleshooting.
Posted 05 August 2007 - 02:05 PM
Aspen is not good at modelling multicomponent towers.
Posted 05 August 2007 - 02:19 PM
QUOTE (AA Mishra @ Aug 5 2007, 02:05 PM) <{POST_SNAPBACK}>
can you suggest what is good?
Posted 05 August 2007 - 03:28 PM
For C1+ hydrocarbon towers, HYSYS (now under "UniSim Design" name) is the best tool I have ever had a chance to work with. It is very intuitive and user-oriented flowsheeter, combining both excellent thermodynamics options and flexibility of simulation.
Do not have experience with Pro/II.
Posted 06 August 2007 - 09:53 AM
CheGuy,
This kind of trouble occurs when it’s fixed reboiler heat duty and it’s so high. So, verify your calculation for reboiler heat duty estimation or try heat duty decreasing in small steps up to ASPEN error warning message disappearing. The last option seems not a polite way. However, an advantage of using simulators packages software is minimize engineering time effort for recalculating by using a try-and-error approach, of course, since problem and process are well understand.
Best Regards,
WSN.
Best Regards,
WSN.
Modeling Liquid-Liquid Membranes In Aspen PlusStarted by Guest_bodinjas_* , 18 Mar 2025 |
No Liquid Phase In Aspen PlusStarted by Guest_PengRobinson_* , 09 Feb 2025 |
![]() Help On Simulation Of Reactor In Aspen PlusStarted by Guest_m.ghaziasgar_* , 06 Jan 2025 |
