Hello every one,
Are there reliable methods of accurately measuring flow rates in pipes without installing any measuring devices inside the pipe dew to the fact that the pipe can not be emptied and isolated. The pipe has no insulation and is 16 inch carbon steel used as part of the blow down network to the flare.
Best regards
Measuring Flow Rates From Outside
Started by Alawi, Aug 08 2007 11:28 PM
Posted 08 August 2007 - 11:28 PM
Posted 09 August 2007 - 12:37 AM
Alawi,
You may consider Ultra-Sonic Flowmeter (clamp-on).
Ultra sonic flowmeter has the following benefits / advantages compare to other type of flowmeters ;
- Low TURNDOWN (can be as low as 2750-to-1)
- "Zero" pressure drop)
- No internal, insertion and moving parts
- Can tolerate certain amount of condensed liquid
- Take higher operating temperature **
- Not affected by gas composition
- No maintenance
** My personal experience upto 260 degC.
Read these...
The Future of Flare Gas Measurement
How much do you flare? How to measure flowrates of flare gas accurately and reliably.
Use Ultra-Sonic Flowmeter in FLARE Gas Header for emission monitoring
Clamp on flowmeter1
Clamp on flowmeter2
Note : Similar post...Flowmeter Type In Flare Gas Header
- No maintenance
Read these...
Clamp on flowmeter1
Clamp on flowmeter2
Posted 30 August 2007 - 11:36 AM
Yes, untrasonic flow meter should be a good choice. At the same time you can have it in a portable form. However, from my experience, it is not as accurate as mass flow meter...
QUOTE (JoeWong @ Aug 9 2007, 01:37 PM) <{POST_SNAPBACK}>
Alawi,
- No maintenance
Read these...
Clamp on flowmeter1
Clamp on flowmeter2
- No maintenance
Read these...
Clamp on flowmeter1
Clamp on flowmeter2
Flow Through A Perforated PlateStarted by Guest_Ahmadhamzahperta_* , 13 Feb 2026 |
Gas-Liquid Pipe Flow Friction Loss CorrectionStarted by Guest_Huba_* , 18 Dec 2025 |
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
