Dear guys,
Hope u all having a great day. I have an issue here that needs your opinions and help.
I work in petrochemical construction company; we use Argon in welding/purging. Unfortunately, the local and the only plant that used to supply us with Argon have had a fire incidents and it is now off-line. The time for the plant to recover is unknown and we are in a serious problem.
I work as a control engineer, just recently graduated, and they assigned me to investigate the usage of Argon in the fabrication shop and the possible alternatives. Argon is used heavily in purging and as shielding gas. Large spools/pipes are fully filled with Argon during wielding especially for Stainless Steel pipes.
Could you please guys give me starting hints or if you have ever faced a similar problem.
Ajlouni
Argon Problem
Started by ajlouni, Sep 08 2007 03:11 AM
Posted 08 September 2007 - 03:11 AM
Posted 12 September 2007 - 04:45 AM
You are in trouble, Tig process welding requires argon as shielding gas, in my opinion, until you don’t get the argon, you have to change for another welding process such as smaw with small diameter electrodes in the first pass for good penetration welds without excess of penetration on the root.
luis marques
luis marques
Lng ProblemStarted by Guest_guoyinyanliner_* , 10 Dec 2025 |
Thermosyphon Reboiler ProblemStarted by Guest_aliebrahem17_* , 22 Oct 2025 |
Material Balance ProblemStarted by Guest_vinnay1999_* , 18 Oct 2024 |
Problem With Writing Offshore Plant Design BasisStarted by Guest_Doneisbetterthenperfect_* , 01 Dec 2023 |
Problem With Writing Offshore Plant Design PfdStarted by Guest_Doneisbetterthenperfect_* , 06 Dec 2023 |
