I am doing a shortcut design on an packed bed deaerator. Background of the problem: removal of oxygen in feed water as part of the process to prepare makeup water for boiler. Feed properties:
T = 50C
O2 = approximately 5.5mg/L
Target= a minimum of 0.005 cc/L of oxygen.
Flowrate of water: 5.4 m3/h
Steam entering from the bottom of the bed is 100C at 101.3kPa(a)
Packed bed is also operating at 101.3kPa(a)
The diameter could be determined from flooding point (page 225 Coulson and Richardson volume 2) - feel free to correct me if there is other method that i should consider in determining the diameter.
I could not determine the height. Can someone please enlighten me?
Thanks a bunch
