My question is regarding depressurizing in HYSYS.
I want to depressurize 24” (ID 547.72 mm, thk 30.94 mm) 52 m length pipe. Pipe volume is 12.3 m3.
Geometry:
2” line present on 24” line. On 2” line there is one RO (Restriction Orifice), upstream of RO there is globe valve and after 600 mm (minimum) there is ball valve after ball valve a spool piece and 24” line. Downstream of RO is routed to vent line open to atmosphere, having approximately 0.2 bar drop in line.
From ball valve to vent line material is LTCS having design temperature -50°C.
After running this model in HYSYS, I am getting final vapour temp as 0.18°C and minimum temp as -2.8°C. Upstream of ball valve line design temperature is 5°C. I want to restrict vapour minimum temp to 5.5°C
Input:
Operating Condition: 86 bara & 22°C.
Ambient Temp = 5°C
Natural Gas: 84.46mol % Methane.
Depressurization Simulation Problem
Started by Zauberberg, Sep 18 2007 12:11 AM
No replies to this topic
Posted 18 September 2007 - 12:11 AM
Ammonium Sulfate Process SimulationStarted by Guest_amir55261_* , 06 Apr 2024 |
Rapid Depressurization Of WaterStarted by Guest_golegolegole_* , 31 Mar 2024 |
Olga And Aspen Simulation SoftwareStarted by Guest_CHEMSTRONG_* , 27 Mar 2024 |
Aspen Hysys SimulationStarted by Guest_amazingspidermean_* , 18 Mar 2024 |
Linear Alkyl Benzene Sulfonic Acid Production (Labsa) SimulationStarted by Guest_Emranm02_* , 03 Mar 2024 |
