How much solids a dusc and donut trays can hadnle? what is the efficeiency of these ttrays? it is low but can nyone is havng idea how much it is?
please help me if u have any information regarding this
Disc And Donut Trays
Started by Rudra, Sep 24 2007 11:37 PM
Posted 24 September 2007 - 11:37 PM
Posted 25 September 2007 - 08:06 AM
I can't read your post, but it looks like you posted it in the wrong forum. Please read the guidelines first, then try posting again.
Thank you.
Thank you.
Posted 30 September 2007 - 12:50 AM
QUOTE (Rudra @ Sep 25 2007, 10:07 AM) <{POST_SNAPBACK}>
Disc and donut trays can handle solids due to their open structure. These are low-efficiency contacting devices but effective in applications where solids / coking is expected and in heat transfer/ quench applications.
Posted 08 October 2007 - 01:59 PM
It's not possible to supply a specific numeric value to your question, "How much solids can D&D trays handle." Like nearly everything in the engineering field, your answer will vary widely depending on the values of other (unspecified) key process and economic parameters. As you can see from the responses, D&D trays tend to be a good choice when (moderate) solids would likely be present.
Doug
Doug
Convert No. Of Trays Into Packing HeightStarted by Guest_T_bag_* , 20 May 2026 |
Theoretical TraysStarted by Guest_guoyinyanliner_* , 27 Apr 2026 |
Rupture DiscStarted by Guest_sima-f_* , 29 Jul 2025 |
Rupture Disc Failure Well Below Max PressureStarted by Guest_vaibhav02_* , 02 Jul 2025 |
Koch-Glitsch Minivalve Trays HysysStarted by Guest_tomr91_* , 23 Jan 2025 |
