Dear friends,
can anybody share ypur experinces regarding problems faced in the evacuated batch reactor.
Problems Faced In The Batch Reactor Under Vacuum
Started by Hariharasudhan.D, Sep 27 2007 06:06 AM
Posted 27 September 2007 - 06:06 AM
Posted 27 September 2007 - 07:37 AM
Hi Hari...D,
Why don't you tell us your own experience/problem and let's see if we can help.
Without any experience, I can say that if you have a vacuum, you can expect mechanical collapse(compression) of the vessel.
Posted 29 September 2007 - 10:29 AM
I faced a problem in ejector side. We use water jet ejectors boosted with steam ejector. If the ejector is boosted for more than one hour water in the tank will get heated up and the vacuum will drop frequently (even cooling water is circulated through the inner coil). Hence booster is recommendable only during evacuation at the beginning hours. After that we can stop boosting with steam. I can share some more problems sooner.
D.Hariharasudhan.
D.Hariharasudhan.
Posted 05 October 2007 - 07:24 AM
Hi aluma,
you have mentioned that there will be mechanical collapse of the vessel, under vacuum.But most of the vessels will be designed starting from full vacuum to the desired design pressure.
Thanks & regards,
D.Hariharasudhan.
Thanks & regards,
D.Hariharasudhan.
Pump Selection ProblemsStarted by Guest_kito-818_* , 14 Nov 2025 |
Vacuum PumpStarted by Guest_R.t_* , 19 Sep 2025 |
Steam Flow And Heating Time In Batch ReactorStarted by Guest_seagal6_* , 16 Jul 2025 |
Batch Adsorption: H/d Ratio For Vessel SizingStarted by Guest_Victor_process_Engineer_* , 28 Feb 2025 |
