I'm building a prototype system with a wet scrubber - I want the scrubber to cool the gases (approx 400deg C) - if it doesn't work out like this I can find other ways to cool it. But I also want the scrubber to remove as much SOx and NOx as poss without absorbing much of the CO2 in the stream, my CO2 content is around 30%, NOx around 0.1% and SOx around 0.2%. I have not much clue on what I'm doing so hoping someone will be able to help me.
I'm building the proto in 6" stainless tube with 3/4' lengths of 3/4" stainless tubing as a packing media the tower will be about 2M high total mass flow rate is around 100kg/hr. Working pressure will be around 5psi (don't you love people who mix metric with imperial measure!!!)
I was going to use a weak NaOH solution to help me capture the acid gases - I'm concerned if I make it too strong I'll have the CO2 being absorbed in it also - (I'm wanting the CO2 for other purposes)
Any help anyone could give me on this would be greatly received
Many thanks
Ben
Naoh Scrubber Sox Nox Not Co2
Started by NZBen, Sep 28 2007 12:24 AM
Posted 28 September 2007 - 12:24 AM
Posted 01 October 2007 - 08:26 PM
Just found out that the CO2 has an affinity to NaOH, any ideas on what would be best to do to remove as much SOx and NOx without the CO2 being taken out also? Cheers
Posted 02 October 2007 - 07:51 AM
I believe many amine solutions and probably other "mild" alkaline solutions are able to absorb SOx and some NOx without significant absorption of CO2. While I've never worked on such a unit, I know they are very common and you should be able to get good information on that approach.
Doug
Doug
Chemical Solution For A Low Abatement ScrubberStarted by Guest_Pheeto_* , 16 Jan 2024 |
Scrubber Fan SizingStarted by Guest_ksagarzazu_* , 06 Jan 2024 |
Type Of Scrubber Needed To Remove Hcl Venturi Or Packed Bed ?Started by Guest_pckr9386_* , 13 Oct 2023 |
Solid Naoh Dissolving In WaterStarted by Guest_lak1r_* , 10 Apr 2023 |
Wet Scrubber Design For Low Flow Rate Of GasStarted by Guest_SIVAMOORTHY_* , 17 Apr 2018 |
