when a elastic material like rubber stretched work done
in stretching against restoring forces is stored as potential
energy,same as a spring.
a rubber can do work if we attach a load to it
while regaining original length.
where as in ideal gas which also resists compression
and that work done is internal energy increase.
why it is not stored as poten.energ.
p.e is arises when ever there is a resistance(force) and work done against it,hence there is change in position or configuratuion,hence p.e.
1. ideal gas compression also has resistence why this not called p.e.
2.if itis not so then how this work of compression rises temperature how can we physically visualise this
rise and prove microscopically ,how their momentum riseby
compression.[FONT=Courier][SIZE=7][SIZE=7][COLOR=blue]
Elasticity Of Rubber
Started by Guest_sunil_*, Jan 11 2004 01:38 AM
No replies to this topic
Guest_sunil_*
Posted 11 January 2004 - 01:38 AM
Clear Or Translucent Material Instead Of Black Rubber For Bicycle TireStarted by Guest_Sergey_NY_* , 01 May 2016 |
Rubber From DisulfidesStarted by Guest_hajar.pour_* , 20 Aug 2014 |
RubberStarted by Guest_a1986_* , 08 Apr 2013 |
Bulk Modulus Of Elasticity Of Lng?Started by Guest_Windswept_* , 24 Jul 2012 |
New Rubber Linned Storage Tank For Phosphoric Acid ImportStarted by Guest_Attyub194_* , 26 Nov 2011 |
