hello.i really need help o my plant design project.i need to recover methanol from a feed that has a lot of components. methyl ester, triglyceride,glycerol, soap,water and other components. is flash distillation a possible solution? i've tried designing a flash drum but i had a problem on finding the data of my components.can you help me?
Methanol Recovery
Started by kayciemae, Oct 11 2007 10:34 AM
Posted 11 October 2007 - 10:34 AM
Posted 11 October 2007 - 10:46 AM
Dear,
For to get the data base of the properties of componenets involved go through Perry's Handbook or
the best option to get all the properties at the respective temp and pressure is to go for simulators
like Hysys.
Padmakar Katre
like Hysys.
Padmakar Katre
Posted 15 October 2007 - 05:18 PM
hi
u can simulate it by distillation column by hysys
and u can enter the specification u want from spec tab in distillation
as u can have multistreams and i think distillation column will cover that
thanx
thanx
![]() Gas Hydrate Inhibition: Calculations For Meg/methanol InjectionStarted by Guest_PYG_* , 30 Sep 2019 |
![]() Methanol Water Distillation ColumnStarted by Guest_Kakashi-01_* , 27 Jan 2025 |
Variables That Affect Energy Consumption Of Methanol PlantStarted by Guest_mobody_* , 15 May 2024 |
