Please can anyone advise on when I can assume gas flow is incompressible. I understand that provided the pressure drop is less than 10% of the absolute pressure, then incompressible flow calcs can be used. Is this true? and are they any other guide rules.
Compressible Flow?
Started by Guest_spiratti_*, Jan 16 2004 06:35 PM
Guest_spiratti_*
Posted 16 January 2004 - 06:35 PM
Posted 17 January 2004 - 02:06 PM
Yes, if the pressure drop is less than 10% of the upstream pressure, then you can use incompressible flow equations for gases/vapors. However, I urge you to look at the the Isothermal flow equation (can be found in any fluids book or Perry's). This is just as easy as using Darcy and you won't have to be concerned about the magnitude of the pressure drop.
Any other guidelines? Just one big one. You must check for choked flow (or critical pressure) first. If you have choked flow or critical pressure, then your pressure drop will be greater than 10% of the upstream pressure and the incompressible equations will no longer apply. This is why I urge you to use the simple Isothermal flow equation. It will apply to choked conditions as well.
Gas-Liquid Pipe Flow Friction Loss CorrectionStarted by Guest_Huba_* , 18 Dec 2025 |
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
Flow & Pressure Regulation For Compressible FluidsStarted by Guest_Abdessamed1961_* , 14 Dec 2025 |
Calculating Gas Flow Rate Without CvStarted by Guest_worrier_* , 25 Nov 2025 |
Seeking Feedback On My Process Flow Diagram. Biogas Steam Reforming ToStarted by Guest_Jacobaum_* , 27 Oct 2025 |
