What does the term "spurious blowdown" mean, in comparison with "Fire blowdown" and "Cold blowdown"?
What is its importance and application?And how does the calculation should be done?
Cheers.
Spurious Blowdown
Started by jprocess, Nov 10 2007 08:46 AM
Posted 10 November 2007 - 08:46 AM
Posted 10 November 2007 - 09:32 AM
A spurious blowdown is an unwanted, unnecessary blowdown. It means that the blowdown valves open when there is no need for it, caused by some system error...
So the importance is that it should be avoided as much as possible and there is no application (by definition).
The term spurious is more often used the combination "spurious trip", sometimes called "nuisance trip".
Surface Area Calculation For Blowdown Orifice Sizing Including FinnedStarted by Guest_victortheone_* , 17 Feb 2026 |
Purging Blowdown SystemStarted by Guest_Ade24_* , 29 Nov 2024 |
Blowdown Ko DrumStarted by Guest_Ade24_* , 13 Sep 2024 |
