Demister Tray
Posted 16 November 2007 - 10:01 AM
Posted 16 November 2007 - 11:05 AM
Fisrt of all let me clear you that the element which is used in knock out drums or flash drums/vessels is demister pad and not the demister tray.Demister pads are porous blankets of wire or plastic knitted mesh, designed and constructed for efficient & economical removal of entrained liquid droplets from vapour streams.I am doubtful if it is used in top of the distillation columns.These are placed where liquid carryover can create upsets in the associated system e.g.if any vessel or equipment overhead is going to compressor suction then to avoid the carryover liquid droplets in compressor suction which will potentially damage the machine.
Demister pads or mist eliminators are used within a process where these particles can cause problems such as corrosion of equipment, contamination of product, fouling of heat exchangers and catalysts and damage to instruments. When released to the atmosphere, these mist particles can cause violations of air pollution emission standards or of opacity regulations.
Posted 16 November 2007 - 11:58 AM
And if don't have Perry's, at least go to your university library and look at it. I would strongly suggest you make an effort to purchase a copy as it will serve you well for many years to come. It can be expensive but as a student you should be able to find a copy with a huge student discount.
Posted 16 November 2007 - 12:36 PM
Demister pad is regularly used on refinery vacuum distillation columns, to avoid entrainment of LVGO product to vacuum system.
Posted 16 November 2007 - 10:57 PM
Thanks for the information regarding the demister pads in refinery distillation columns which I was not aware.I found those mainly in KODs.
Posted 20 November 2007 - 10:00 AM
Posted 26 November 2007 - 01:00 PM
Attached I send you a Mesh blanket article in PDF format, with a sample problem.
Please read it and understand the complete article for apply the sample problem.
Additionally, look at: http://www.acsseparations.com/, the "Mist Eliminator Design Manual" . to ACS
Posted 22 June 2011 - 11:11 AM
Attached you find the the complete article that I had sent in 2007.
And additionally the excel spreadsheet.
Good luck.
Edited by Profe, 02 April 2012 - 02:48 PM.
Posted 28 June 2011 - 01:02 AM
http://www.amistco.c.../MeshVaneSM.pdf looks a good guide for mist eliminator design, although the supplier of it usually selects type of mist eliminator and exact location of it (*). Flow rates, components, gas and liquid temperature, should be specified by the Process Engineer of the Plant, being aware of potential corrosion or plugging problems. Diameter of entrained particles can be difficult to specify (we did not in the case of Fertilizers), but supplier could make a rough estimate out of general conditions (e.g. spray data of the said column along with gas rate); or you can base the mist eliminator on another one installed and successfully operating.
ΔP through the mist eliminator is given by supplier.
(*) Location can be also specified by Plant Engineer, according to design practices (e.g. for drums).
Edited by kkala, 28 June 2011 - 01:08 AM.
#10
Posted 06 July 2011 - 12:14 PM
Probably this is not voluntarily sent by ZYPeng, it might be some kind of malware / virus spread over. I have seen this automatic sending of e-mails in my work computer. I remember a similar "advertisement" propagated in our forum in the past (most probably in Jan 2010), which was soon cleared off. Same is expected to be done now.Hi ZYPeng
I think that this class of commentaries are not well received in this Forum!
Its a waste of time.
Petrosim Tray SizingStarted by Guest_tomr91_* , 27 Feb 2025 |
Uniform Vs Non-Unfiorm Tray In HysysStarted by Guest_tomr91_* , 23 Jan 2025 |
Chimney TrayStarted by Guest_tomr91_* , 20 Jan 2025 |
![]() How Is The Performance Of The Distillation Tray Calculated? The DistanStarted by Guest_Ahmedforup_* , 11 Oct 2024 |
Flash Tower With Tray In Deoiling Of Wax?Started by Guest_AnbIran_* , 01 Jul 2024 |
