hello friends,
i am simulating a crude refinery case, everything thing is fine but i have stuck up with crude desalter i dont no how to define it. i am charging 1139t/hr crude at 40deg after passing it through heater it gets heated upto 133 deg and 15kg pressure then a desalter is present D/S of heater where i m charging 70t/hr water 40deg and removing brine 78t/hr at 40 deg and 5kg pressure. please guys help me in installing desalter.
Hysys 3.1
Started by muddu4, Dec 20 2007 04:26 AM
Posted 20 December 2007 - 04:26 AM
Posted 20 December 2007 - 11:31 AM
So what is your question? What doesn't work in your simulation, or don't you get the results that you expected? Please be more specific, specify compositions, temperatures, pressures, flow rates, preferably a sketch of your system, how did you simulate it (what unit operations did you use) and what is your specific question?
Posted 26 December 2007 - 11:39 PM
QUOTE (joerd @ Dec 20 2007, 11:31 AM) <{POST_SNAPBACK}>
i have attached PFD of the case i am simulating (crude distillation column), i just dont no how to attached crude desalter which is U/S of distillation column.
Posted 27 December 2007 - 08:27 AM
Try using a 3-phase separator. Hysys will require you to attach a vapor stream, but its flow rate will be zero.
Posted 27 December 2007 - 09:16 AM
Dear,
Just try use a component splitter.Hope it will work.
Posted 24 March 2008 - 11:43 AM
I have not seen a crude distillation column with 76 trays.
Maximum 45 trays is sufficient to do the job.
Please verify your data.
Aspen Hysys - Creating A New Component And Defining PropertiesStarted by Guest_catiiiii_* , 22 Apr 2024 |
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
Extension Reaction Kinetic In HysysStarted by Guest_Ulbert Zsolt_* , 29 Mar 2024 |
Aspen Custom Model Won't Load Into HysysStarted by Guest_SaintLazarus_* , 21 Mar 2024 |
Aspen Hysys SimulationStarted by Guest_amazingspidermean_* , 18 Mar 2024 |
