I am Anil Panchal, engineeirng student in SVNIT-Surat, India. I am having project on design of Pneumatic Conveying System. My duty is to convey Magnesium Sulphate Anhydrous at the rate of 1.5 tonne/hr. I have done calculations using book "Pneumatic Conveying Design Guide" by David Mills. Following data I have used. I want to know whether my calculations are right or wrong because my conveying temperature is 125 deg. C and particle diameter is 2 mm.
Duty
Horizontal conveying = 120 m
Vertical conveying = 12 m
Required material mass flow rate = 1.5 tonne/hr
Material = Magnesium sulphate (Anhydrous)
Particle density = 2660 kg/m^3
Particle size = 2 mm
No. of 90 deg Elbows = 2
D/d for elbows = 7
Temperature of air = 125 deg C
Data Taken for Design:
Allowable pressure drop = 0.2 bar
Minimum conveying air velocity, Cmin = 16 m/s
Conveying line inlet velocity, C1 = 1.2 x 16 = 19.2 m/s
5” schedule 40 pipe, ID = 128.20 mm
I have used “Pneumatic conveying design guide” by David Mills.
Results obtained
Air mass flow rate = 0.26 kg/sec
Material mass flow rate = 1.78 tonne/hr
Volumatric air flow rate = 0.212 m^3/s
Please give suggestions.
Pneumatic Conveying Of Magnesium Sulphate Anhydrous
Started by Anil Panchal, Jan 01 2008 12:13 AM
No replies to this topic
Posted 01 January 2008 - 12:13 AM
Iron Sulphate Heptahydrate ProductionStarted by Guest_baam353_* , 19 Jul 2025 |
Air Supply To Pneumatic HoistStarted by Guest_Im97_* , 25 Nov 2024 |
Hydrated And Anhydrous Form CrystallizationStarted by Guest_Izaaz_* , 01 Sep 2023 |
Sizing Pneumatic LineStarted by Guest_kangas_* , 04 Nov 2021 |
Non Refrigerated Anhydrous Ammonia Storage And TransferStarted by Guest_Fragile_Bacon_* , 21 Nov 2019 |
