The problem consists that at the top of our crude oil distillation unit (atmosferic), the top vapours temperature is higher than the last packing section (lowest part).
The packing section consiste of 125x structured sulzer, 23.46" high an 15'6" diameter.
I would like to know if there is a simulation sofware or analitical method that we can used to explain this operating behaviour.
Thanks all of you
Temperature Inversion At Crude Oil Distillation To
Started by José Utrera, Feb 10 2004 11:51 AM
Posted 10 February 2004 - 11:51 AM
Posted 10 February 2004 - 06:20 PM
Mr. Utrera:
Only for curiosity, do you check the temperature sensor?,
does the temperature indicator was calibrated recently?.
does your tower highest? if the answer is true, i am not sure (is only an idea) maybe it would be explain for low winds (it sounds very rare)´.
Best regards,
Frank. C
Best regards,
Frank. C
Guest_Guest_prashant_*
Posted 22 April 2004 - 01:49 PM
Dear Sir,
We have observed recently that a calibration converter can give erratic reading.
Second possibility is the location of the Thermowell. If the thermowell located near packings is in the dead zone then a slight difference can be there.
Happiness Always,
Happiness Always,
Posted 31 March 2005 - 12:20 PM
Normally in an atmospheric crude oil distillation you have from top to bottom 1-Naphta cut around 120 ºC, 2-Kerosene cut around 200ºC, 3-Light gas oil cut around 280ºC and 4-Heavy gas oil cut around 320ºC. The column feed inlet is around 375ºC. What cut are you speaking about?
Luis Marques
Luis Marques
Posted 08 September 2005 - 09:46 PM
I wonder if Mr. Marques is talking about the light distillates
Have you checked the reflux velocity yet
Posted 17 September 2006 - 01:07 AM
It is possible that you have vapor – liquid maldistribution in top packed bed. Reason for that can be liquid distributor or packed bed problem caused by improper installation, column upset or corrosion. To confirm this you can try to cut holes in column insulation in level of packed bed and measure column shell temperature, if temperatures have significant difference you have vapor – liquid maldistribution
Centrifugal Compressor Cmpression Ratio /discharge Temperature LimitStarted by Guest_Lyne_* , Yesterday, 03:11 PM |
Organic Peroxide Distillation IssueStarted by Guest_Kimbreaux_* , 19 Feb 2026 |
Relieving TemperatureStarted by Guest_Falah_* , 01 Feb 2026 |
Crude Assay Pure Component AdditionStarted by Guest_darknight1991_* , 17 Jan 2026 |
Short Path Distillation Rotor SpeedStarted by Guest_MEC_* , 11 May 2023 |
