In the equation K=f * L/D, is L/D constant for pipe sizes over and above 24"? I see a chart in Crane Technical Paper 410 but it only goes to 24". This is for pipe sizes over 24". Thanks.
Calculating K Values For Pipe
Started by , Jan 23 2008 10:52 AM
Posted 23 January 2008 - 10:52 AM
Posted 24 January 2008 - 06:06 AM
We need more specifics. Are you just concerned about straight pipe or are there fittings involved? What fittings do you see being part of the system?
Posted 24 January 2008 - 09:46 AM
QUOTE (pleckner @ Jan 24 2008, 03:06 AM) <{POST_SNAPBACK}>
Long Radius 90 degree elbows for instance. I see that L/D for a butterfly valve changes with changes in size, but does this happen with an elbow? Or, what would the L/D be for even a butterfly valve beyond 24"? For pipe sizes that go over and beyond the standard 24". Thanks.
Posted 24 January 2008 - 07:22 PM
What you want to do is calculate your L/D from K/ft, where ft is the friction factor at full turbulent flow. For the elbow, you would probably use an r/d of 1.5 and this corresponds to a K of 14ft (chart on page A-29). So L/D would be 14. For these larger sizes, you can get ft from the graph on page A-23.
But warning! These large pipes are not Schedule 40 so you need to adjust the K value for the new Schedule basis. See page 2-10.
I think you could benefit from my paper on K values and equivalent lengths. You can get this paper from this site:
http://www.cheresour.../eqlength.shtml
Posted 24 January 2008 - 08:00 PM
Thank you soo much for your helpful responses.
![]() Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , 20 Jul 2025 |
![]() Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
![]() Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
