Dear Cheresources,
can some body enlighten me the difference between edible phos acid and commercial acid. How can the edible Phos Acid is manufactured from commercial acid.
My mail address : kkrao22@hotmail.com
Phosphoric Acid
Started by Kameswara Rao, Feb 17 2004 12:22 PM
Posted 17 February 2004 - 12:22 PM
Posted 19 February 2004 - 06:16 PM
Hello:
I think that this link could help you to know the difference between both.
http://www.fenghaichem.com/p3.htm
Best Regards,
Frank. C.
Best Regards,
Frank. C.
Guest_P Venugopalan, Galfar Engg_*
Posted 15 February 2006 - 07:37 AM
QUOTE (Kameswara Rao @ Feb 17 2004, 12:22 PM) <{POST_SNAPBACK}>
Dear Cheresources,
[font=Times New Roman][b]
G'men,
The main application of commercial phosphoric acid is for manufacture of phosphatic fertilisers and other industrial products. The acid is made from Phosphate rock (containing tri calcium Phosphate and impuriyies like Fe Mg F Sio2 and traces of radio active materials etc)
But the application of edible acid is for use in animal feed, soft drinks etc and hence requires thorough purification steps.
Please refer book on Phos acid by 1 AV Slack and 2 Becker (both from Marcel and Decker} for more on the subject.
Venugopalan
Posted 06 July 2006 - 04:40 AM
Phosphoric acid can be manufactured by two method: wet method and funace method. The first one is use for fertilizer prodction and the second is use for other purpose such as food of animals and etc. I think edible phosphoric acid is the acid which is produced by the seconf method!
Heat Of Dilution Of Hydrogen Chloride In Hydrochloric Acid Solution (3Started by Guest_fredlan54_* , 21 Nov 2025 |
Phosphoric Acid 56% Tank LiningStarted by Guest_Phosphoric123_* , 20 Apr 2025 |
Equilibrium Data For Nitric Acid And WaterStarted by Guest_ksagarzazu_* , 07 Oct 2024 |
Acid Base ExtractionsStarted by Guest_paradoxlost_* , 07 Jul 2024 |
